I have a 10w Falcon laser attached to an old Ender. I upgraded to add an air assist (Air Assist for CR-Laser Falcon Engraver | CrealityFalcon CA)
But it no longer cuts properly. In a single pass it is underpowered and a THICK line scorches the material offset by about a cm from the cut line.
There were two lenses included in the kit, I swapped out to the second lens but now it does not even engrave materials.
I uninstalled the air assist, and with the original lens it now works fine.
Thoughts or things to try before I go the return route?
thank you.
