Trying to split a model
This is a model of a Milwaukee drill holder that I downloaded and printed, which worked great. However, now, I just want to print one additional copy of the one on the left. In Tinkercad, if you try and click on them, they appear as one block and the un-group feature does not function. My first thought was to use the hole function over the one I don’t want but this does not seem to work either. I’m using Creality 7 so if there’s a way to do it in that it would be great as well. Thanks.
Hoping to get some assistance splitting this model apart. I want to print only the one on the left but if you try and click on it in Tinkercad, they just appear as one block and the un-group feature does not function. My first thought was to use the hole function over the one I don’t want but I cannot separate them. I’m using the Creality 7 so if there’s a way to do it in there that would be great. Thanks.
High Allen. You can use the slit command in creality print or import the .stl file into Microsoft 3d Builder and use the slit command to divide the file.
Bill
If what @Bill.b suggested doesn’t cut it maybe try using the cut feature in Creality Print.
You’ll get a warning message but it will still separate the objects.
If you right click the model in Creality print does it give the option to split to parts or split to objects ?
