unable to connect to moonraker after update
after a recent update ive not been able to connect to moonraker via fluidd any help would be appreciated.
K1C rooted
Since you have your K1C “rooted,” did you restore it to default before upgrading the firmware?
If not, then that is more than likely your problem.
In settings close to where you enabled root access, you should find an option to restore to default or restore to factory default.
Then enable root access, re-download the Creality Helper Script, and install Moonraker and any other software you had installed before.
Ahhh…I did not I’ll try that
any solutions?
Basically restored to factory And reinstalled the script
Is a factory reset before upgrading anything or just the firmware? I had this issue after just upgrading moonraker for the fluidd menu.
I’m doing a factory reset now, but seems like overkill.
i didnt have to on the last recent moonraker update and i updated it through the fluidd iinterface
with that said the last time i did that i had to reset the firmware so idk…try to update through whichever frontend you use worst case scenario you have to resetand start over
are you updating klipper or the mainboard firmware??
If you can’t connect to fluidd or mainsail after update of moonraker, simply switch power off and on again and it will work…
