Using cut on an object more than once
I’ve got a k2 plus and I’m trying to use the keyed cut function in Creality print 7 on a 14 inch donut shape.
To get it small enough to print I need to slice into 3 pie shape pieces. The problem is when it applies the cut it cuts through the other side of the model I don’t want to cut. Anyone have any ideas how to do this in Creality print?
Thanks in advance
Steve
Humm, dont think you can do that.
Hi, did a cover 14 inch, cut it in 2 pieces, place one at 45 angles or so and print one at a time.
It won’t work for a donut shape I need each piece to have a key into the next. When I cut one key it cuts straight through the other side. And doesn’t put a key there.( If I would id print it in 4 segments)
Thanks
Steve
