Z-Offset Troubles, Always getting a different Value
Hi everyone, this is my first post trying to get help.
I’m having issues with my z-offset, every time i make the PROBE_CALIBRATE comand, gives me different values.
I was printing with no issues, and using in every print the same Z-Offset, suddenly after changing the filament and starting other print, i began to have troubles with the offset.
then, I started to babysteping z-offset while printing, but every time a get a offset, the next print need the offset to be far from the bed like .050 or .1
now i have the offset set to -.141
every probe calibration. this value start to raise.
Now, I try to use BED_MESH_CALIBRATE, but suddenly the printer stops, sending in the screen “Key 2060” here’s the Log
12:54
{“code”:“key60”, “msg”:“Internal error on command:BED_MESH_CALIBRATE”, “values”: [“BED_MESH_CALIBRATE”]}
12:54
Klipper state: Shutdown
12:54
probe at 5.000,215.000 is z=-0.287795
12:54
probe at 5.000,162.500 is z=-0.186781
12:54
probe at 57.500,162.500 is z=-0.011672
12:54
probe at 110.000,162.500 is z=0.119502
12:54
probe at 162.500,162.500 is z=0.156070
12:54
probe at 215.000,162.500 is z=0.250051
12:53
probe at 215.000,110.000 is z=0.321683
12:53
probe at 162.500,110.000 is z=0.257264
12:53
probe at 110.000,110.000 is z=0.207823
12:53
probe at 57.500,110.000 is z=0.125306
12:53
probe at 5.000,110.000 is z=-0.060805
12:53
probe at 5.000,57.500 is z=-0.073622
12:53
probe at 57.500,57.500 is z=0.121246
12:53
probe at 110.000,57.500 is z=0.226621
12:53
probe at 162.500,57.500 is z=0.264598
12:52
probe at 215.000,57.500 is z=0.299706
12:52
probe at 215.000,5.000 is z=0.261503
12:52
probe at 162.500,5.000 is z=0.237860
12:52
probe at 110.000,5.000 is z=0.232939
12:52
probe at 57.500,5.000 is z=0.104704
12:52
probe at 5.000,5.000 is z=-0.008804
12:52
bed_mesh_calibrate
I already tight the belts.
I’m ussing Mainsail, i’ll try to get back to stock firmware.
Does anybody has some trouble like this one before?
Thanks fot the help
I feel you. Do not relly on the auto leveling function of the printer. That made me buy a new plate, because no filament was placed on the plate!! Everything was in the air.
I manualy dial the Z axis offset, and i get perfect prints. Today it gave me a value of -1.53.
At that value, the nozzle was in the air! Don’t know why. Maybe the probe needs to be cleaned.
At -2.08 printer prints as a charm!
