How to tight printhead on CR6SE problem
  • I had nice experience with my CR6 but I noticed some vibration and I tried to tight the printhead, but I am currently failing.
    The print head is a little loose, causing some issue in the bed leveling for some corners.
    How do I fix it? which bolt should I tight? Is the belt?
  • I found it, there is nut between the head enclosure and the bottom wheel that can be used to tight the printhead.
