Doesn't recognise disc
Purcashed a new Ender 5 Pro a couple weeks ago. Worked fine. After last print for some reason the disc was compromised and would not work. I reformatted disc only to find when I place in printer it could not find it. Even with a new disc, printer could not find it. Any ideas what I can do to fix.
Make sure that the format is only fat32
Cheers
- by disk did you mean micro/sd card
- if so and you are using a pc/mac you need to tell the pc what format to use, try formatting card in Fat32
hope this helps you
