Creality New 3D Printer CR-200B
  • Hi, all Creality's friends:
    How are you doing
    Creality has new stuff out, CR-200B, it is totally different from obvious products. https://www.creality.com/goods-detail/creality-cr-200b-3d-printer
    Minimalist industrial
    Completely enclosed chamber
    Filament breakage sensor
    Large-size color touch screen
    Internal LED light
    https://youtu.be/U6Mi0TtOZw8
  • Dear @Vivek
    Could you provide a video that we can check the issues? Thank you
  • A query regarding CREALITY CR-200B.
    I have a problem in it. When the power is on, it is working normally but when the power is down the bed is floating downwards and after the power is on, the bed is not returning to its place, so that the print is floating. Could you please tell me how to rectify this defect.
  • uncheck Origin at center, then your print will be placed as you position it in the slicer.
  • @admin Hello, I just got the printer and for some reason it's not printing in the center of the build plate - it prints a little to the left and down. I'm using the Creality 4.8 version of the slicer program. But when I print one of the samples that came with the printer, it prints perfectly. I have read on different forums that others are having the same problem. Can you please let me know why this is happening? Thanks.
  • @admin
    My printer is working fine after some upgrades.
  • Dear @marian @SyntaxNero @Mr-T
    If your CR-200B doesn't work well, could you please send me the serial number, that we can check which batch of the machines are and give you the best professional after-sales service. Thank you for supporting .
  • @Mr-T Hi,
    for CURA I recomend to download Creality slicer-4.8.0:
    https://www.creality.com/download --> Software (it's in Portuguese language, but you can change it to eng). Creality slicer is re-branded CURA software.
    From there you can export/rewrite setings to CURA.
    About the issues with jamed filament/underextrusion/.. please check these:
    https://youtu.be/TGULhT8droY
    https://youtu.be/W-XunEfPHsI
    https://youtu.be/ZKLf-mYD6cY
    https://youtu.be/ku_0sHfmcDM
    maybe you have the same issue.
    Marian
  • @marian
    Hi ,
    I have bought this printer also but i need the CURA settings that are best for this printer .
    Did you already have your printer setup?
    Mine doesn't work well , i hope due printer settings....
    Filament is often jamed and bigger surfaces sometimes not even filled.
    If you have a solution already i would like to hear from you.
    Kind regards
  • Hi , you have to unmark the "Origin at center" Value
    Greetings
  • Did you find correct settings? This printer in on they way to my home, but it's little bit scary now. Forum with 2 topics only, both issues and no reply from Creality...
  • I need the proper settings to load into Ultimaker Cura for this printer.
    Nothing I do will make it print in the center.
    Printer Setting:
    X - 200
    Y - 200
    Z - 200
    Build plate - Rectangular
    Origin at center - X
    Heated bed - X
    Gcode Flavor - Marlin
    Printhead Settings:
    X min - -20
    Y min - -10
    X max - 10
    Y max - 10
    Gantry Height - 200mm
    Number of extruders - 1
    Start G-code:
    M82 ;absolute extrusion mode
    M201 X500.00 Y500.00 Z100.00 E5000.00 ;Setup machine max acceleration
    M203 X500.00 Y500.00 Z10.00 E50.00 ;Setup machine max feedrate
    M204 P500.00 R1000.00 T500.00 ;Setup Print/Retract/Travel acceleration
    M205 X8.00 Y8.00 Z0.40 E5.00 ;Setup Jerk
    M220 S100 ;Reset Feedrate
    M221 S100 ;Reset Flowrate
    G28 ;Home
    G92 E0 ;Reset Extruder
    Stop G-code:
    G91 ;Relative positioning
    G1 E-1 F300 ;Retract a bit
    G1 E-1 Z0.2 F2400 ;Retract and raise Z
    G1 X5 Y5 F3000 ;Wipe out
    G1 Z10 ;Raise Z more
    G90 ;Absolute positioning
    G1 X0 Y0 ;Present print
    M104 S0 ;Turn-off hotend
    M106 S0 ;Turn-off fan
    M107 ;Turn-off fan
    M140 S0 ;Turn-off bed
    M84 X Y E ;Disable all steppers but Z
    M82 ;absolute extrusion mode used to override G91
    Extruder 1:
    Nozzle - 0.4mm
    Com Mat Dia - 1.75
Copyright © 2020 Shenzhen Creality 3D Technology Co., Ltd All Rights Reserved.
