Configuring slic3r???
What do I put in the ???
Flavour of gcode???
Size
Nozzle diameter?
Filament diameter
Extrusion temperature?
Bed temperature?
Thanks!
@tyoc213 said in Configuring slic3r???:
Flavour of gcode???Marlin
Size
The bed size, 235 x 235
Nozzle diameter?
Your nozzle diameter, unsurprisingly. 0.4mm is common, but put whatever you have on there.
Filament diameter
See above. 1.75mm unless you've changed extruders/hotends.
Depends on your material. Like it says on screen, 160-230°C for PLA is good. I'm running 210 degrees centigrade for my Octofiber PLA.
Bed temperature?
See above. Again, as the screen says, 60°C for PLA is a good rule of thumb. Personally running at 55 degrees centigrade for the Octofiber filament, but depends on your material.
