Ender 3 V2 - manual leveling issue
Hi,
I have a new Ender 3 V2 printer.
I am trying to do the manual bed leveling, but I have an issue.
The bed with the tempered glass is very high and even when I turn the leveling knobs counter clockwise (to the lowest position) , the rear side of the bed is touching the nozzle (when set with auto home feature)hos can I make my bed go lower ?
or is there a problem with my z-axis stop switch location ?
how can I understand where the problem is ?thanks.
I guess you are not using an Bed-Leveling sensor like the BlTouch right ? If it is so, then you can try to set your Z-Endstop higher, until your height ios good, otherwise try to set your Z-Offset, for Sample: M206 Z-0.2 will raise your Nozzle 0.2mm higher than normal, save it after you finetuned that with an m500
Greets
AsusDK
