Configuration File for Ender 3 V2
I found out, that on the Ender 3 V2 the content of the eeprom would be saved on the microSD into the eeprom.dat file. I suppose that the motherboard has an eeprom. If I'm right, I would like to know whether this feature will be enabled in the future and why it is currently disabled. Furthermore, it would be interesting to know if creality is intended to transfer the menu structure of the predecessor model also in the V2.
Thanks
Semmi
@admin said in Configuration File for Ender 3 V2:
@Semmi Dear, so your problem is solved?
Whether or not @Semmi has solved it with Marlin 2.0.6, it would be good to see it enabled on the official firmware.
I found out that on Marlin 2.0.6 this issue was fixed.
