After the updating "CR-6 SE-V2.0.1.2 firmware" I cant change language
Hi
When i finished to update firmware "CR-6 SE-V2.0.1.2 English" i couldnt change language from the screen menu. i touched the screen but no response to enter language menu.
could you help abt above mention
thank you
Hi,
I am also having the same issue to change the German language into English.
Thanks for the best solution.
That was the previous release of 2.0.1.2 released on the 17th of November, that was later removed.
Also he manages to update it in the video, if you actually watch past the beginning. At around 6:15 you see the update running and the numbers incrementing with each file being copied from the SD to the MCUs memory. Afterwards he re-assembles the LCD an is able to change the language without issue.
Same problem occured to the other guy
CR-6 SE Firmware Update V2.0.1.2
With the information "it didn't work" it's really hard to say.
The most common problems seem to be people having the files in the wrong folder on the SD, having the wrong files on the SD or having the SD card not formatted properly (FAT32 with 4K sector size).
@shinmai so what you suggest
i tried many times. what was wrong?
This post is deleted!
Yeah, that's not a successful update of the LCD. The numbers represent the files being updated. If they show all zeroes, no files have been changed on the LCD.
yes, actually it happened after that. I was proceeding according to tutorial video. But i realized that i didt wait 1 min during lcd firmware update. it suddenly below screen appeared and showen "sd card Process ...end" as they inform.!
but when you check the numbers of the files which they are right side on screen all is "0" maybe. in video it shows some numbers 1.2.3 something like that
Did you also update the LCD firmware? You need to update both for a lot of the menus to work with the new FW.
