SD Card Reader no longer working
I successfully made a few prints with my CR6SE last month, but haven't used the printer for a couple of weeks. Today, I attempted to print files and the reader would not recognize my new g-code files.
At first, it recognized the files I printed last month, but then didn't even read them after a few attempts.- Tried both the 8mb card from Creality and an 8mb Sandisk.
- Reformatted both cards. Full format to FAT32
- Put only one file in the root directory of the SD card, with no other files and folders.
- Tried inserting card with printer on, and inserting while machine was off and then restarting.
- Tried pressing on the card a little to make sure it's seated while attempting to read.
Nothing seems to be working. I notice that the locking mechanism that is supposed to hold the card in until you push and then remove doesn't work either - you can just pull the card straight out.
These cards both read just fine in my PC and in other devices
My backer # is 4,577 on Kickstarter. Do I need a new card reader or motherboard? Please advise.
After contacting Naomi Wu, she must have pulled some strings because my new MB showed up air express within a few days, I’m keeping it as a backup, since I have the BTT board and display in hand to install.
@Defens In my case the card showed up after a couple of weeks.
Probably is cheaper and faster replace the card.
@Defens After an initial email response that Creality agreed to replace my motherboard I’ve seen no more response in over a week. Do these guys just go dark and not fix anything, or should I expect to just see a board to show up one day.
@Defens said in SD Card Reader no longer working:
Unless you're prepared to do SMD desoldering and soldering, these are functionally the same thing.
Given that the locking mechanism is malfunctioning, you'll probably need to have it replaced somehow; even if it did read the cards, without having the card locked in, there'd be a constant danger of prints failing because of the card losing contact inadvertently mid-print
