Grinding X
Unboxed my new Creality CR-6 SE. Super excited to start, powered it on, to level and find that regardless of the tension I place on the x-axis I have intermittent grinding.
Any fixes?
@admin I get an intermittent grinding noise on the X and then the print will shift. I posted in another thread and it was suggested to look at the belt tightness/alignment. I'm trying that solution right now.
@JTrimper
Hi Sir, could give more information about the issue?
I've been having a similar issue. Was there any recommendation?
Dear @kenthompson1
I can't open your video, If you send the same video to our email address, I think they can't open it as well.
I will push our engineer to answer your questions.
Same issue with mine. And mine also fails to home now. https://drive.google.com/file/d/1XGue6SNQtnKxYh1u0F3uTK_r2MxC9BQ7/view
I emailed the address provided below. Hopefully then can send out a replacement board ASAP.
@Jimmielt3 Dear, it is X motor is shaking, or other situations, please provide a video to cs@creality.com for analysis. Thank you
