Print does not start after BLtouch autolevel
I am using a Ender 3 V2
yesterday I installed BL Touch module from Antclabs.
I changed the firmware to following from Creality site:
"4.2.2 Ender-3 v2 Marlin2.0.1 BLtouchV1.1.1without adapter board firmware"My board version is 4.2.2 and the JST connector from BL touch is directly connected to the board BL touch port.
Then I changed the Z-offset to -3.1mm
Auto leveling woks fine and G29 command goes does it fine.
But my prints does not start.
I tried both from SD card and directly from USB
Heating and leveling/homing part works. But right at the printing phase it stops.
I see on terminal following output where the error starts:
Send: N9 G28*26 Recv: TT::200.56200.56 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6969 BB@@::2424 Recv: Recv: echo:busy: processing Recv: TT::200.56200.56 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6969 BB@@::2424 Recv: Recv: echo:busy: processing Recv: TT::200.52200.52 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6969 BB@@::2424 Recv: Recv: echo:busy: processing Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::8181 BB@@::2424 Recv: Recv: echo:busy: processing Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7979 BB@@::2424 Recv: Recv: echo:busy: processing Recv: TT::200.07200.07 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7676 BB@@::2525 Recv: Recv: echo:busy: processing Recv: TT::200.56200.56 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6464 BB@@::2525 Recv: Recv: TT::200.52200.52 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::6565 BB@@::2525 Recv: Recv: echo:busy: processing Recv: TT::200.03200.03 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7777 BB@@::2525 Recv: Recv: echo:busy: processing Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7575 BB@@::2626 Recv: Recv: echo:busy: processing Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7474 BB@@::2626 Recv: Recv: echo:busy: processing Recv: echo:busy: processing Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7474 BB@@::2626 Recv: Recv: TT::200.00200.00 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7373 BB@@::2626 Recv: Recv: echo:busy: processing Recv: TT::200.03200.03 //200.00200.00 BB::60.0060.00 //60.0060.00 @@::7272 BB@@::2626 Recv: Recv: echo:busy: processing Recv: TT::200.00200.00 //200.00200.00 BB::60.0160.01 //60.0060.00 @@::7373 BB@@::2222 Recv: Recv: echo:busy: processing Recv: X:155.00 Y:130.00 Z:13.00 E:0.00 Count X:12400 Y:10400 Z:5200 Recv: ok Send: N10 G1 Z2.0 F3000*42 Recv: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) Recv: ok Send: N11 G1 X0.1 Y20 Z0.3 F5000.0*30 Recv: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) Recv: ok Send: N12 G1 X0.1 Y200.0 Z0.3 F1500.0 E15*83 Recv: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) Recv: ok Send: N13 G1 X0.4 Y200.0 Z0.3 F5000.0*55 Recv: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) Recv: ok Send: N14 G1 X0.4 Y20 Z0.3 F1500.0 E30*121 Recv: Printer stopped due to errors. Fix the error and use M999 to restart. (Temperature is reset. Set it after restarting) Recv: ok
what is the problem with setup ?
I am not sure about the correct Z-offset but I guess this is not the reason for the error.
Re: Print does not start after BLtouch autolevel
I'm seeing the same thing on my printer after upgrading firmware to the latest on Creality website. Basically I can't use the auto level feature at this time. If I level the bed by hand I can print with out doing the autolevel before hand. If I use autolevel and then try to print it just sits there after heating up. I don't currently have my printer hooked up to an external device to watch the logs so couldn't say if the errors are identical or not, but the behavior is.
Ender 3 pro 4.2.7 main board + Bltouch
FW - Marlin 1.3.1 2020-04-25
Same problem.... Do you resolved this problem?
