CR-10S Pro V2 LCD Display
Can anyone tell me, when you slice something with different printer settings (nozzle temp, speed, fan, bed temp) than what is the default on the machine, should it show on the screen?
For example, my current settings on the printer are 200 for nozzle temp, 50 for the bed, 100 for the speed and the Fan on. If I bring up a gcode file with an object that is set to print at 210 degrees, 50 for the bed, 50 for the speed with the fan off, when I go to print it still has all the original settings listed. I can't tell if it is using the gcode settings and not displaying it, or if it ignoring the gcode settings.
Thanks.
