Ender 6 in Cura 4.8.0 : possible solution
I have it working on the Mac and also a windows installation in a VM.
They have to be clean installations though, I have had some errors when adding the Ender 6 files after I had already run Cura before doing the changes. Deleting the user-data in the ~/Library/Application Support/cura worked for me.
I used the Ender6 files from the Creality slicer. I had to change the version of these files, and also change a few files to make the profiles work with the materials again. (There has been a default name-change along the way which broke things: 0.4mm to 0.4mm Nozzle)
It appears to work although because of a broken fan I have not printed anything.
A file with the files to add can be found here:
https://www.dropbox.com/s/tqq6bx115n57eio/cura_resources.zip?dl=0
step 1
Do a clean install of Ultimaker Cura and/or make sure to remove all user settings- MAC: remove ~/Library/Application Support/Cura
DO NOT RUN Ultimaker Cura yet!!!
step 2
Copy provided files to their respective folders in the resources folder of your installation- MAC: /Applications/Ultimaker Cura.app/Contents/Resources/resources/
- WIN: C:\Program Files\Ultimaker Cura 4.8.0\resources
Overwrite when prompted
Start Ultimaker Cura - you should be able to choose the Ender 6 printer now.
I really appreciate this. I'm a Mac user with no 3D printing experience and literally just put my Ender 6 together yesterday. I am new to everything so when I could not find an Ender 6 profile in Cora, I stopped in my tracks wondering what to do next and thought I should edit the Creality profile of the printer which seemed to have the closest specifications. Anyway, thanks. However, perhaps you could clear up a little confusion, why does the profile say 260mm x 260mm x 400mm when the Ender 6 is 250mm x 250mm x 400mm?
