CR10 S PRO will not pause with M0
Hi,
I want to pause a print at a certain height to place nuts as thread inserts but my printer will ignore the M0 command. Printer does move ahead away from print but returns to work immediately without user input.I have used Cura and Creality slicers, and even direct gcode editing without success. M0 is simply ignored.
Is my only option to modify the printers firmware to enable M0 commands?
@gtrmx I'm having the same problem. Did you figure out a fix for this? It's driving me crazy.
Hey gtrmx,
You can pause the printing for a specific amount of time by using the G4 command : G4 P4000 will pause the printer for 4 seconds. so if you add a G90 command to move the carriage out of the way and then use the pause command, it might get you what you want as long as you are near the printer when that time comes to pause.
Of course this does involve modifying the g-code file and adding commands where you want them to take place.
Dear @gtrmx, Can’t pause printing and insert other models to print. After pausing printing and continuing to print, only the currently printed model can be executed.
Thank you.
