Powers off when trying to heat
Ender 5 pro first time using it. When the heat bed or extruder tries to warm up, it powers off and then back on. Reconnected all the wires and still does it. Any help would be greatly appreciated!
@jcurlyk did you check that the switch for the voltage is correct for your country? Mine was set to the higher one and had similar problems.
