Your browser does not seem to support JavaScript. As a result, your viewing experience will be diminished, and you may not be able to execute some actions.
Please download a browser that supports JavaScript, or enable it if it's disabled (i.e. NoScript).
When I try to enlarge an already existing hole the object splits as so there is no adhesion between the layers. I use Esun ABS filament, 0.2 layer height. 230 degrees hot point 80 degree bed temperature 70 mm/sec speed pleas suggestions Dov
