CURA 4.8 retraction settings
Hi everyone, my CR6 is printing generally well but there is still more stringing that I would like, using PLA.
My retraction settings with CURA 4.8 are 6 mm distance, 25 mm/s speed.
Does any one has good results with different values?
I am been having a hard time getting consistent good results.
At first I got good results a retraction 4mm and 45mm/s., But began experienced stringing, also in the first layer.
After extensive use of stringing towers.. again, I have settled on 6mm and 35 mm/s., Z-hop enabled at 0,2mm. I get consistent good results now, I am printing square houses which are quite forgiving for stringing in my, very limited experience. But for now I am happy.
I started having adhesion issues, think its caused by underextrusion, After much fiddling I raised bed temp and nozzle temp for the first layer by 10 degrees(70/215 with Prusament), and filament flow to 110%. first layer Now I get nice adhesion and first layers.
I am about to change filament supplier, so all this may change shortly
