Not reading files on SD card
The gcode files loaded to the SD card are not showing on the 3D printer menu (only shows "Back") . I have formatted the card (Fat) and checked that the files are downloaded on the card when connected to my computer directory - USB Drive: (E).
Has anyone received any response or resolution to this issue? Is the only solution to replace the main board?
Hi. @Craig you can fill your issues and attach pictures or videos in this link:
https://www.creality.com/service-request. There will be professionals to help you.
I have a new Ender 3 v2 that won't read the microSD card. I can view the files when I put the card in my laptop and it is formatted FAT32. It is the card that came with the machine. Has anyone else experienced this problem and found a resolution for it?
@Craig I'm having the same problem with my brand new CR-6 SE. Which model are you using?
