Creality CR-10 VS CR-10 V2 VS CR-10 V3 3D Printer: What are the Differences?
  • Other than the Creality Ender-3 3d printer, no other Creality 3d printer has had the ability to accomplish the sustained popularity of the Creality CR-10 3d printer, which appeared in 2016 and also boasted an ultra-affordable price incorporated with an uncommonly generous print volume for the time.
    In order to extend the popularity of its classics, Creality continues making modifications to produce a seemingly never-ending series of iterations. These include the Creality CR-10 V2 3d printer and the Creality CR-10 V3 3d printer, both of which refine Creality's original proposition somewhat.
    Creality CR-10 VS CR-10 V2 VS CR-10 V3 3D Printer: Differences
    From the chart above, we can easily make a conclusion on the differences between each two.
    Upgraded from Creality CR-10 3d printer, Creality CR-10 V2 3d printer gets some improvements as follows:
    1. Creality CR-10 V2 3d printer gets an additional pull rod to form a more stable “golden triangle” frame design.
    2. Creality CR-10 V2 3d printer has a 24 V/350 W Mean Well power supply to provide a stronger power supply.
    3. Creality CR-10 V2 3d printer upgrades its motherboard with TMC-208 ultra-mute drivers.
    4. Creality CR-10 V2 3d printer is equipped with dual-port cooling to improve heat dissipation.
    5. Creality CR-10 V2 3d printer supports filament sensor detection and to ume printing function.
    Being the latest version of Creality CR-10 3d printer, Creality CR-10 V3 3d printer gets more improvements based on CR-10 V2.
    1. Creality CR-10 V3 3d printer supports the updated Marlin 2.0 firmware.
    2. Creality CR-10 V3 3d printer has a default direct drive extruder, which will better support soft material like TPU.
    Design: Revamp into a More Noticeable Appearance
    The Creality CR-10 series share the same design on the control box, which somehow increases the footprint of the printers. However, this easily noticeable feature helps users easily tell the CR-10 series from the other Creality 3D printers. Besides that, the Creality CR-10 and CR-10 V2 3d printer set the spool holder above their control box.
    Creality CR-10 V3 3d printer, on the other side, relocates the spool holder to the top of the printer. This makes the system, on the whole, much more stable, though at the cost of increasing the height of the printer.
    An additional design element that distinguishes the original Creality CR-10 3d printer from the subsequent versions is the golden triangle structure. It describes the Z-axis
    This describes the Z-axis brace connecting the top of the structure to the base. This must give the printer a stronger structure, as well as is featured with the objective of minimizing resonances as well as Z-wobble showing on prints.
    Basic Glass Bed vs Carborundum Glass Bed
    The Creality CR-10 3d printer has a basic glass print bed that isn't textured, whereas the Creality CR-10 V2 and V3 3d printer have carborundum glass beds, which have has a seemingly porous layer that grips prints when warm. The benefit of this appears because prints will stick better to the print bed, and has the perk that they are easy to be removed from the platform.
    With the CBedreality CR-10's basic glass print bed, glue might be essential to make certain the first layer of your prints stays put. As soon as they've completed and also cooled, you might additionally require a spatula to assist pop prints off.
    Stepper Motor Drives: All about Silent Printing
    An additional difference that distinguishes the Creality CR-10 3d printer from its more recent brother or sisters, namely the Creality CR-10 V2 and CR-10 V3 3d printer is the stepper motor drivers. The Creality CR-10 V2 and V3 3d printer both have TMC-2208 ultra-mute drivers, which utilize micro-stepping to smooth out the activity as well as get the stepper motors whirring under 50 decibels-- quieter than the air conditioning fans, which are the only points you'll listen to when running the Creality CR-10 V2 3d printer as well as CR-10 V3 3d printer.
    Extruders: Step Further to Reliable Extrusion
    The extruders are likewise a noteworthy distinction between all versions of the Creality CR-10 3d printer. The initial Creality CR-10 3d printer has a relatively standard MK8 extruder, with the supply V2 not much better with an all-metal version that asserts boosted durability. Both are installed to the X-axis gantry, pushing filament to the hotend with PTFE tubes.
    The V3 includes a direct drive Titan extruder as a criterion. This feature generally provides an easier time loading filament than the awkwardly put Bowden extruder of its precursors, and also you may see far better efficiency when retracting filament, thanks to the shorter path to the warm end.
    Power supply: Efficiency in Heating Up
    In terms of power, the primary distinction between the original Creality CR-10 3d printer and the V2 as well as V3 is a switch from a 12 V to 24 V system.
    The original Creality CR-10's power supply isn't really powerful (users complained the 12 V power supply caused the bed took permanently to warm up and also then wasn't one of the most consistent), however, the later iterations include a 24 V/ 350 W Mean Well power supply and also 24 V warm end and also a bed. So, if you value your time and printing in products that call for a heated print bed is a must for you, avoid the Creality CR-10 3d printer.
    Single Motor-Driven Z-Axis vs Dual Motor-Driven Z-Axis
    Creality CR-10 V2 3d printer and Creality CR-10 V3 3d printer have dual motor-driven Z-axes, unlike the original CR-10, which just has a single motor-driven Z-axis. The benefit of the dual Z-axis electric motors is that it boosts precision while printing. This improvement also contributes to longer service time for the printer's mechanical elements.
    Which One Should Be Your Final Choice?
    In regards to the user experience and print performance features, the V2 and V3 are clear victors, leaving the original Creality CR-10 3d printer behind. A much better power supply, a filament run-out sensor, boosted motor drivers, and a tougher structure all make the V2 and V3 better than the predecessor. That being claimed, these upgrades do come at an expense. The Creality CR-10 3d printer is without a doubt the least expensive choice with a sub-$400 price, complied with by the Creality CR-10 V2 3d printer at around $499. Last comes the Creality CR-10 V3 3d printer which sets you back about $530.
    For a first-timer simply wanting to obtain their feet damp with 3D printing, the Creality CR-10 3d printer is a strong choice as the cheapest of the 3.
    The Creality CR-10 V2 3d printer simply slips it for us if you're looking for a machine that you can rely on more. The Creality CR-10 V3 3d printer runs with newer firmware and a direct-drive extruder, which are tested to confirm these points of benefit for the user. You can upgrade the Creality CR-10 V2 3d printer to Marlin 2.0, as well as outfit it with the direct drive extruder at your convenience. Boom, Creality CR-10 V3 3d printer, if you also need it, that is.
    Inevitably, the appeal of all three of this equipment is that they are endlessly upgradeable. Despite your choice, there are basically endless opportunities you could take them.
  • Dear @MichaelD
    Thanks for your suggestions, I will feedback to our product manager. Thanks for your support.
  • I think Creality almost became king-of-the-hill with the CR V2 and V3 series. The large build volume was outstanding.
    But then Creality stumbled (In my opinion) when they used a bordon-tube lined hot end and limited the temps to 260C. Upgrading the hot end on the V2 is not difficult but the V3 is a whole 'nother matter. It's difficult and expensive.
    If I were buying a CR10 today, I'd buy the V2 and immediately upgrade the hot end and extruder for something a little more capable.
