Another Adhesion problem Ender 3
Hi All,
I had gotten hooked on 3D printing with a Dremel 3D45 that was available to use at work, and for Christmas I got an Ender 3 (Not Pro or V2) Finally got it set up last weekend, and the only thing that prints well is the 3 models that are on the SD card. I've cleaned the removable build surface and re-leveled, but anything I slice in PrusaSlicer (newest version with their Ender 3 config from the setup wizard) or Creality Slicer will not adhere with the first layer. The skirt slides across the surface as it tries to lay it down. If I go back to print the dog on the SD card, it adheres and starts building correctly. I already opened a support ticket, but hoping someone has an idea for me.
Thanks,
Jason9
