CR10 S-5 Brand new heatbed will not heat beyond 73 C
  • I am trying to commission a brand new S5. It is assembled and connected per the instructions. When I tried to heat the machine up for a test print, the bed heated to between 70-73 C and then says:
    Heating failed
    PRINTER HALTED
    Please reset
    I've tried several times, both with the glass on and with it off and I get the same results. I've checked the pins on the connector and the sockets on the P/S. I measured voltage at the connections on the heat bed and I get just over 11VDC when the bed is heating.
  • @sfindley23 The maximum temperature supported by the CR10 S-5 hotbed is 60 degrees
