Problem with Intenso SD Cards?
Hi,
after reading that bigger SD Cards make problems I ordered some smaller ones just for convenience from Intenso.
But the CR-6 can't read them and I do not talk about updating the Firmware. Just the normal reading for gcodes files.
How is it possible that a normal SD Card reader can't read SD Cards with exactly the same Standard as the SD Card which came with the printer? 8GB, SDHC class 10
How sensible can you make a reader 2020. This should be standard software and not any proprietary stuff, right? Can you please let me know what is going on here? I already even tried formatting with FAT32 and 4K blocks as it seems to be needed for Firmware updates.
But nothing helps. The printer simply does not show any files.Thanks
thor
