Slice Engineering Mosquito Hotend
Anyone knows how to calibrate the PID on the CR-6 SE.
Planning to purchase a Mosquito but I need some help calibrating the Thermistor as I plan to run some PEEK material.
Any suggestions or link redirections will hep a lot.
@capn-stretch you'll need a custom compilation of the firmware. The thermistor is not compatible with the default compilation, and the default maximum temp is ~275°C. You'll need to change both at the very least. The same goes for if you switch to some other main board as well. Not to mention all of the other changes required to print PEEK.
