Ender3Max
I recently purchased an Ender-3Max printer, my first 3D printer. So far, it has been a good experience as long as my part size fit the parameters of a Ender-3Pro, which I have loaded into the slicer program. Now I am trying to print a part that is 10" diameter and the slicer doesn't like it, as it exceeds a 3Pro capacity. Changing the parameter values in the profile didn't have any effect. So far I haven't been able to find a source for a slicer program/profile that will handle a 12 x 12 x 14 work envelope and is compatible with, or specifically for, the 3 Max. Anyone else been here and found a solution?
Dear @CREE
If you need to print large parts, you may consider cutting the parts into multiple parts and assembling them, or purchasing a larger size printer.
@CREE Try using Cura
