CR10 V2 Error - Message "invalid data"
Hi and good Moring,
Starting the PSU i've got the Erro "Invalid Data". Sometimes after inserting my SD Card. Print jobs craches and stops with the same error Message. I doesn't matter if I use SD card or USB-Port. The print jobs stops not at the same layer. It stops whenever it want to stop. Means: The same Print job stops at a hight e.g. 5 cm, 7,5 cm, 4 cm. I have no idea what the issue could be.
I use:
Cura slicer: 4.8.0
CR10 V2 Stock: only xyz and e are calibrated by changing the values in the printer Settings
File valumen: 19 MBDo you have any idea, what wrong?
Best Regards
Nobby66
