Temperature not reached error.
  • Temperature stops 10 degrees below set temperature and then varies slightly to stabilize 10 degrees below until the system shows the error message. Flashing firmware, restarting etc did not work. Checked all connections and replaced nozzle. If adjusting up while stuck it continues app and occasionally it passed the threshold to reach the maximum 260. However on the next part the problem remains!!
    ![0_1614454948688_B2D8E990-D47F-4A76-942D-DF6C3A8ADA51.jpeg](Uploading 8%) )
  • Dear @designtowork
    Check the wiring connections to see if the thermistor is faulty, if the nozzle can not be heated to replace the thermistor try.
