3D printer corrupts my SD card
Hi there,
Bit of an issue with my CR6SE.
Printing went fine until today my printer couldn't read the G-code files anymore.
Not even G-codes I've already printed that were still on there.
The SD-card itself can't even be opened on my computer. I even can't format it anymore.
So I thought the SD card itself just broke so I boucht another one.
But after I loaded a new G-code en stuck it in the printer I had the same problem. Not reading and I can't open it on my computer nor can I format it.So Ithink the printer dit someting with it but I have no clue what it is. Can't find anything online so a little help would be nice.
Greetings!
@Ownmaxd My TF to SD adapter caused a similar issue. If you're using one try changing it over.
