4.8 Slicer, expected default language English. Actually Portuguese, bug/intended?
problem: Just downloaded and installed 4.8 Slicer, expected default language English. Actually Portuguese, bug/intended?
cause: Testing process broken?
work around: Change language preferences in settings and restart slicer software.
Dear @aaronse42 @gigor
The slicer 4.8 is only for the Portuguese language, if you use English, please download other software in our website. Thank you for your support.
and after some time it reverts to portugese.
Better use the original Ultimaker Cura 4.8 version, creality slicer is just a custom frontend of that, done by who knows...
and it's done bad, the splashscreen shows portugese and chinese instead of being just global english.Or try out the new Cura Arachne BETA, which uses a new way of calculating the print. Does still contain bugs however.
Creality got some work to do in using and being a standard.
