Print splitting in middle
I have the ender v2 and have never had an issue with printing until now, the print is splitting toward the middle, it looks like it not lined up. Once it gets passed that one spot it starts printing correctly again. The top and bottom are completely fine, doesn't seem like a clog any recommended on how to fix this?
TIA
@KrazyKreationzS Try removing the Z-Axis lead screw then manually sliding the carriage up & down to check it is smooth. Be sure to hold only the left side when doing this to be representative (unless you have dual z-axis setup
Any notching in movement can upset the accuracy of positioning.
