Print using TF Card to Micro-usb adaptor?
Hi, I am a proud new Ender3 owner. I find these tinsy cards a right pain. Is it possible to print from the TF card through an adaptor into the micro usb port?
Thanks.
@Thomas4ff yes it is. But the printer doesn't detect when the card is removed or replaced in the reader. I had to keep removing and replacing the ribbon in the tf slot which is annoying. If you put the card in before powering on its not so bad.
