Pause ay height FAIL (M0 and M1)
Firmware tested 1.70.2(factory set), 1.70.1 and 1.70.2
I tried from cura and creality slicer to add pause at height script but always failed.
I noticed tha the M0 command and the M1 doesn't read from printer.
Also tried M0 S10 or M0 P10000 or M0 <message> but no success.
suggestions plz?
thnx in advance!!!
Dear @hwa_rang098tkd
EDNER-5 PLUS does not support automatic pause, the motherboard firmware does not support it.
thnx but i mean what code i have to use in order to pause automatically? instead of m0
@hwa_rang098tkd
To replace the consumables, you need to heat the nozzle to 200 degrees. You can press the extrusion clamp with your hand to pull out the consumables, or you can move the extruder to extrude the consumables
thnx you for the reply.
What I have to do in order to change filament ?
the only way is to press it in lcd screen by myself?
EDNER-5 PLUS does not support this function.
ender 5 plus ....
yes @hwa_rang098tkd, we are glad to give a suggestion, please send the machine type.
