CR-01 Manufacturing Fault from New
  • I have a CP-01 3 in 1 machine from new.
    The plastic extrusion head works fine.
    However, from new the Laser and CNC heads do not work.
    On inspection those 2 heads are using Pin 6 and 11 of the 15 way plug.
    Pin 11 has no connection inside the machine.
    Pin 6 is used by the thermostat.
    So, the heads are not compatible with this machine.
    There are 2 solutions.
    You supply compatible laser and CNC heads.
    Or, you supply workable wiring diagram so I can connect the heads.
    Thank you.
    Malcolm
