Creality CR-10S Print Problem Extruder
I do not know what is causing this, but it is printing very loose between the layers. No matter the setting I change in Cura I have not been able to correct it. ( I been Unable to add some images of the problem)
Dear @robomaster
Check whether the machine nozzle is clogged, if the nozzle is not clogged, it is recommended to check whether the slicing parameters are set incorrectly, such as extrusion multiplier, or try to restore the default parameters, if it still does not work, you can try to brush the firmware
