CR-10 V3 Changing filament
I have just got my printer and was wondering
what is the excepted method of swapping / changing from one filament to another?
As far as I know it does not have an unload function or am I wrong?any help will be greatly appreciated.
regards
John
@Oldsubguy86 If you are getting a 'change filament' message, although you have not run out of filament, then it is a problem with the filament sensor and/or sensor wiring. Some people have reported problems with intermittent sensors on this forum.
I have bypassed the sensor on my machine (https://forum.creality.com/topic/2004/creality-cr-10-too-much-friction-resistance-in-the-filament-detector) so you could do the same (...just so that you can get on with printing a few objects and make sure that there are no other problems with your machine) while you look for a solution.
When I say "bypassed" I mean I have cut a short length of filament and pushed it into the filament sensor, and then run the filament directly into the print-head/extruder.
@SteveDee I just finishing putting my together and started my test print I pretty much immediately err change filament. Not sure how because I have not even got my first print done.
I'm pretty new to this myself, but as no one has answered so far, this is what I do;
- pre-heat the hot-end (185'C for PLA)
- while its heating up, raise the print-head to (say) z = 100mm via the menu
- once heated, rotate the cog on the print-head forward and insure that hot plastic is extruded (i.e. no blockage), and then remove the extruded piece of plastic
- rotate the cog backwards while holding the filament with the other hand, pulling lightly to sense that the filament is coming out
- once the filament is free of the jaws, you will be able to just pull it out
- re-load new filament
I hope that helps.
