Issue with stopping mid print
I have been running my ender 3 v2 for about 3 months now, ran over 150 prints, worked great! I use creality slicer that came with my machine and it has worked wonderfully. The issue is that over the past 2 weeks about 90% of my prints have stopped printing midway and dont allow me to finish. it is quite frustrating, i have emailed creality service and received nothing in response, I have checked on other forums and asked other owners and was told to check many things, of which i did, and they did not fix the issue. Temperature is between 69-73 deg F at all times, humidity is low enough iv never had to put filament into a dry area and never had any issues relating to humidity.
My Machine:
Creality ender 3 v2
4.2.2 motherboard (just 2 days ago upgraded to the 4.2.7 from creality)
SIBOOR Dual zaxis stepper motor kit
CHpower all aluminum extruder kit
Blue capricorn bowden tubing
upgraded springs with aluminum adjuster wheels
Hardened steel 0.4 nozzle
upgraded glass bed
printed chain covers for wires
printed filarment holder bar to reduce the pull on the extruder and roll
running 1kg rolls of PLA from sunlu, hatchbox, and geeetech
I run almost all my materials at 205 deg and 60 bed tempAttempted fixes:
New sd card (reformatted old and new to fat32 and tried again)
New slicer- tried ultimaker cura slicer newest version
custom STL file of a simple box (18.5mm tall worked 4 times but 25mm did not finish)
New motherboard
Shut down for 2 days with no power connected
cleaned hot end
cleaned whole machine of all dust (btw you dont even realize how much dust gets inside these machines)
releveled the bed
updated firmware
I have now also tried the grounding issue fix- scratching the paint off by the screws in back and adding a piece of metal between the y stepper motor and the structure
