Ender 6 no filament error when trying to print
Just bought and assembled Ender 6, but unable to print any samples, receive no filament error. Filament is installed all the way to the nozzle and thru the detector and extruder. When I press the 'yes' button, nothing happens.
Telephasic is right, it's either bad hardware or a wiring issue, since you should have a blue light showing on the detector when a filament has been inserted.
I had the same issue. The only way I was able to get around was to unplug this sensor from the board. Once you remove the plug the printer will print. I also just bypass this det sensor for filament, running it beside vs through. Hope this helps.
A blue LED on the sensor should be lit when printer is powered on and filament is installed.
If not, seems it's a wiring/hardware problem.
@moranhaus I'm having same issue on my Ender 6... have you found a solution?
