Ender 6 Bowden Tube
Nice printer but having real issues with the bowden tube - it's constantly pulling out of the fitting on the feed side - which ends up with ruined prints and lots of plastic on the floor. This is in the as shipped configuration. Switching to high quality tubing to see if that fixes it but thought should be given to using higher quality tube on this machine. The standard tubing as shipped isn't cutting it.
@warddw hi, first change to Capricorn XS and replace the extruder near the Z rollers rails, the shorten a max the bowden .... like this https://youtu.be/9UAAzYEvXjs
Just wanted to know if you've had any luck switching tubes, I'm having the same problem.
