Issue with thin gaps !
  • Hi ! I've an issue with all the gaps !
    For example if I've a slot where to insert a carboard object; the printer doesn't print correctly the channel so i cannot use it !
    Same thing printing philips oneblade combs ! I cannot insert the blade in the slot !
    I'm using a clear "Esun waterwashable resin" . ( i'm not at home! I will write all the settings when I'll be there )
    Do you have some suggestion ?
