Ld002h screen turns black and reset mid print
  • My printer started having this defect sometimes where it would randomly stop mid print and kinda reboot /shutdown randomly bought it in April..
    Sometimes I can print 3-4 times before having the issue while it can happen to me twice in a row.
    Pretty sure it isn't slice related since I often just reprint the same file and it turns out ok.
    Anyone else had this issue?
  • @Kyrha1719
    hi,
    if you don’t receive an answer/solution from Creality:
    • have you occasionally a static discharge when you touch your printer?
    • have you some electrical glitch from your power network?
    • can you to confirm that the voltage input of your power plug is in the range?
  • hello, Kyrha, please fill in the detailed fault information under this link, and special personnel will handle the fault for you.
    https://www.creality.com/service-request
