CR10s Pro V2 Prints always have artefacts
I have had the CR10s Pro V2 for about a month and still can't get the settings tuned no matter what I change in Cura there are still these random protruding bits. Each print has different settings, I have mainly tweaked retraction distance, speed and flow and had no look. I am currently using esun pla+
Below is the last lot of settings I used, I know the speed and distance for the retraction are high but I have worked my way up starting off low.Any help would be appreciated.
I usually set the parameters。
Dear @HarrisEnt
After consulting with our technicians, they recommended that you try the parameters in the figure to set the print
