Menu Help.
What is the way to get an SD card to refresh? After a print I must shut off the printer to read any new additions I put on the SD card. Once I power cycle, I see the new info. Really need a manual that explains the menu choices on this as i's so different than my older Ender 3 Pro.
@ewashburnaf Which version are your looking for?
@JoeBob Have you updated firmware to the latest version? I was having issues with SD card data loading, until I did the latest firmware update.
Good luck with ever getting a manual on any of that with Creality. They really should, but never going to happen.
This video is the BEST you may ever see. Hopefully RuiRaptor makes one for the new 32bit Ender 3 V2...but the firmware can change things depending if Creality updates their firmware or custom by others.
timid1971 is correct. Also on the V2 what are he meaning each of the Icons on all screens.
Joe
The feature he is looking for is under the setting on Ender 3 and Ender 3 Pro:
PRINT FROM SD -> and REFRESH
(Depending on version, similarly PRINT FROM TF -> and REFRESH TF)(CHANGE TF ->)But it is nowhere to be found on the Ender 3 V2 as some other features.
Is there anyone at Creality that specializes in this that can clarify things?
Thank you.
@JoeBob, Hi, may I know which 3d printer menu are you looking for. so that I can send you the URL to download. thanks
Well that sucks. Hope a firmware revision adds this among other features that are missing that were on the Ender 3 and Ender 3 Pro.
