cr10 v1 shrink firmware
Hello
I have a CR10 with v1.1.2 board, 8 bit sanguino. I have recently bought upgrades, new direct drive extruder and a bltouch but I am unable to apply all necessary features in vscode without running in to firmware size problem. I have tried everything for days.. Is it even possible to achieve this?
im at 96% memory used and Im trying to activate babystepping and babystepping wizard to be able to tune the Z axis on display.
This is what i have done so far in merlin 2.0 bugfix with melzi_optimized_optibot
disable STRING_CONFIG_H_AUTHOR
disable SHOW_CUSTOM_BOOTSCREEN
disable CUSTOM_STATUS_SCREEN_IMAGE
enable DISABLE_M503
disable EEPROM_CHITCHAT
enable SLIM_LCD_MENUSConfiguration_adv.h
enable SDCARD_READONLY
enable NO_VOLUMETRICS
enable NO_WORKSPACE_OFFSETSbuild_unflags = -g -ggdb
build_flags = ${common.build_flags} -fno-tree-scev-cprop -fno-split-wide-types -Wl,--relax -mcall-prologues -finline-limit=3 -ffast-mathanything else i can disable?
Thank you for the suggestion. I might try that.
Can you recommend any new board that fits my CR10 printer?
This post is deleted!
@BobKriss said in cr10 v1 shrink firmware:
I think that by the time you have turned off features to fit you won't have BLTouch or babystepping etc.
The last , most feature rich Marlin version for those boards was 1.19 I think. The 2.0.x Marlin is unlikely to fit with the features you want.Good luck though, Let us know if and how you did it. Otherwise I might suggest to update the board to go with all those upgrades. You won't regret it. Fully featured latest Marlin 2.0.9.1 bugfix is < 290K compiled. With newer boards having 32 bit with minimum 512K, plenty of room and speed.
BaDboD
