Sounds like prints stick to FEP
I'm new to resin printing and when my build plate lifts out of the resin bath it sounds like it is tearing the print off of the FEP film. I've had several failed prints where the part breaks off of the supports, and sticks to the FEP film. Today I sprayed the FEP film with WD40 PTFE spray (this was recommended as a solution for sticking parts on another forum), but it is still making the same sound. The sound gets larger the bigger the part becomes.
hi,@Arno_81 The bonding FEP film is normal. it's possible that the bonding area between the printed model and the FEP film is too large. you can adjust the printing angle of the model to make the bonding area between the model and FEP film as small as possible
