USB Stick Ender 5 Plus
I do not like using the mini SD card - The Ender 5 plus have a mini USB port - If I get an adapter - Mini USB to FEMALE standard USB - Can I plug in a normal USB stick ? Much easier to have the files on a normal USB stick than to use a small SD card.
Thanks in advance
Hi, @ian555 we don't recommend you do that, because the printer can't recognize USB stick with high probability
