Cr6 SE Calibration Problem
  • Hi eveyone,
    On my CR6-SE, i have made all necessary calibrations via printing 20mm xyz cubes.
    After the calibration, when i print the same 20mm xyz cube, the print comes with accurate dimentions which is 20x20x20.
    But when i try to print something bigger like 150 x 30 x 20 mm the print's dimentions comes so much different than what i have designed.
    What should be the problem? Any idea to fix it?
    Appreciate.
  • hi,@samethalic how much the size difference is, and slight size difference is allowed. Can you upload a detailed picture or video of this issue?
Copyright © 2020 Shenzhen Creality 3D Technology Co., Ltd All Rights Reserved.
