Gaps between lines on surfaces (no gapes on walllines)
  • Hello,
    I have a problem on the first layer I already see that the lines are not completely connected, on the right side they are connected on the left side is about 0.5 mm gap between each line.
    The mesh level is all on green, it can't be because of that (community firmware).
    Offset is at 0,20.
    What can be the reason for this? Shouldn't I go down 0.15 with the offset?
    I have already calibrated the extruder, should I calibrate again, but this time with a bowden tube on it so that it also presses through the nozzle?
    What else can this be (I can not provide a photo at the moment).
    Thanks in advance.
  • Hi, @omexlu
    1.Please clean the nozzle and throat first, you can refer to this post that has some video tutorial on cleaning nozzle and tube.
    https://forum.creality.com/topic/2670/video-tutorial-on-cleaning-nozzle-and-tube
    2. It is possible that there is something wrong with the slicing parameters. please print our test model to see if there will be any problems.
    3. If there is still problem, please send an email to cs@creality.com and attach pictures or video.There will be professionals to help you.
